Jeep Wrangler Door Hinge Bushings
mecheng10
Magnitude Engineering's premium line of replacement bushings for Jeep Wrangler, CJ, YJ, TJ, and JK door hinges will allow you to replace your deteriorated, worn out, or missing OEM bushings with ease. Whether you are trying eliminate unsightly rust, compensate for years of wear, fix that door that won't latch properly, or prevent potentially damaging leaks due to door misalignment; replacing your bushings is the simplest and most cost effective way to improve the appearance and operation of your door.
Simply remove the old bushings if necessary and insert new ones in their place without the extra time and expense of purchasing new hinges, removing the old ones, prepping and painting, or aligning. As opposed to replacing your hinges, replacing only your bushing minimizes the risk stripping a screw or damaging paint.
Magnitude Engineering's premium replacement bushings are precision machined from high lubricity Delrin® bar. They firmly support loads in both the radial and axial directions due to their full length barrel and flange. Because of the self-lubricating nature of the material, these bushings do not require additional lubrication. Unlike OEM bushings that are roll-formed from flat sheets of laminated material, these solid bushings will not flake apart or delaminate.
These bushings are designed to fit OEM door hinges on Jeep CJ ('76-'86), Jeep Wrangler YJ ('87-'96), Jeep Wrangler TJ ('97-'06), Jeep Wrangler JK ('07-'10) models. JK hinges are different than those used on CJ, YJ, and TJ models and require different bushings (listed separately below).
They are sold in sets of 4 or 8 pieces; enough to rebuild 2 or 4 doors respectively.
Magnitude | Products
New Product Offering Coming Soon!
Stay tuned for a new Jeep Wrangler product offering from Magnitude Engineering - coming soon!
