originalrider41
Having trouble starting an 04 after it sits for any longer than say an hour. Turn the key and the only thing that happens is the engine light turns on, no clicks or cranks. It can be started by dumping the clutch on the roll and once its running the engine light goes off, also it will be able to be started with the key (so far) if started shortly after it is turned off. Im sure if I had a scanner or code reader it would be fixed by now but obviously I do not. Anybody have a guess on what would cause my problem? I believe it's some safety relay or something of that type but would rather not replace every one.
