70worm New member Jan 15, 2011 #1 I have a 91 yj and I was wondering if an od trans from a cherokee would be an even swap?
xjmarc New member Jan 19, 2011 #3 You'll need the TCM to make it work but it can be done. The AW4 is a pretty good transmission too.
Bounty__Hunter Super Moderator Jan 20, 2011 #4 The AW4 transmission from an XJ is a great option. www.stu-offroad.com/engine/aw4/index.htm
Bounty__Hunter Super Moderator Jan 20, 2011 #6 No it's far from a direct swap. Check out the link I posted, the same mods will likely apply to you.
