coilovers????
Mudjunky
Just wanting to know some pros and cons on coilover shocks? What is required to install them? is the exspence worth it? Can coil overs give you adj.ride height?
to the actual coil over, there is no Con except for price.
there is a lot of suspension setup and geometry knowledge needed.
you need to know what your spring rate are going to be; example main spring, tender spring.
understanding of link seperation values, squat and anti-squat values, etc..
Honestly, it is not a simple as installing a bolt on long arm kit. if you have never consider building a double triangulated four link from scratch, it is something best left to experts.
