I know this has been asked a thousand times, but what kind of rub if any will i get from 32's on a CJ5 with a one inch body lift? I plan on a suspension lift soon but the tires are coming first. thanks
I have a 2 1/2" suspension lift and my 32's rub under articulation if the tire is turned slightly. If you just have a 1" body They will rub off road and probably pulling into the grocery store parking lot too. It also depends on the tire manufacture. Some 32's are actually 31's. You could probably make it for a little while before you got mad enough to pick up a suspension lift.
