Steering
chopper
Just lifted my 98 grand cherokee 4" can't find a dropped pitman arm! Is there any longer drag links out there?
You shouldn't need a drop pitman arm as long as you don't install a bracket that lowers the axle end of the trackbar. Buy a good adjustable front trackbar like a Teraflex unit and you should be set.
Your goal should be to have the draglink and trackbar parallel to each other.
