Welcome to JEEPZ.com. The cable you found is for the transfer case and only shifts from 2wd to 4wd modes. Look for the automatic transmission shift cable on the driver's side above the pan. It will be attached to a lever which is mounted on a shaft that goes through the neutral safety switch.
