oil pressure problem
IrishMike
I have a 97 jeep sahara 4.0l engine. I live in hot florida. The problem happened with a drop in oil pressure at idle and knocking. I rev engine and stopped briefly and started again. I had new oil and filter recently. I am questioning the oil pump, oil filter type, and oil used 5w 30 regular. i had the jeep towed so as to not ruin engine. Any help or ideas would be appreciated.
Thanks Mike
I also live in Florida, run fram filters, and 10w40 oil. Change the oil every 2500 miles. I would look at oil pump first.
P.s. how many miles?
Thanks for the input. We are replacing the oil pump and dropping the oil pan is a bear. An exhaust pipe runs accross the oil pan and runs back thru catalyic converter into muffler. You know to disconnect the muffler is not going to just pull apart. I can not believe they engineered the jeep exhaust across the oil pan. Well we will work it out somehow. thanks for input. Mike
