Rotorhead907
Hello.  I did a 4 inch lift on my cj5. It originally had a 2 inch lift with 31 inch tires. I put 37 inch tires and they clear the front pretty good. No rubbing. It has an AMC 20 rear and a Dana 30 front. The rear axle is stamped "A" meaning it came with a 3.54 gear. The P O. I bought it from said he changed it out to 3.73. I took the rear diff cover off and counted the teeth. Yup, 3.73. So with the 37 inch tires, I know I have to re gear. Question, what kind should I get? The engine is a rebuilt 258 with a 2 barrel Ford motocraft 2100 carburetor.  The transmission is a 4 speed manual T-18 transmission with a granny 1st gear. I will be using it as a daily driver and will be 4 wheeling in the dirt, sand, and hills. Nothing wild. I saw the chart and I could go up to 4.88. Any advice will be great. Oh, and where can I get a rebuild kit for the front and back axle? A full kit, no just the ring and pinion. Thanks,  Mark.
