I would like to get some longer studs for my Dana 44. What is involved in pressing them out? Can I do it myself? What about putting the new ones in? Where can I get some studs that will fit my holes?
If you are not going to reuse the studs a big hammer will push them out.
when putting new ones in
1 put the new studs in thru the back of the axle end
2 get 2-3 grade 8 washers (hardened) place them over the stud sticking out of the axle end
3 put a lug nut on backwards (flat side against washers)
4 use air gun to pull stud thru
5 keep checking the back so when the stud is flat against the axle end your not still cranking the air gun, and messing up the threads.
as to where to get new longer studs I am not sure.
if you can take one of the ones you removed from the axle,take it to any parts store and see what they have,maybe?
