M240_Storm
The idea:
To install 2 batteries in the jeep. I already have them.
To connect both of them through a switch that will connect as selected by the switch. It will enable to use battery one as the only battery.
Or it will enable to use battery two as the only battery.
Or in extreme cases connect both in parallel.
The need to have the switch is because I have 2 batteries and they have the same electrical characteristics but they are not the same age, so one battery will not charge the other.
The problem:
Would the switching affect the controller (Computer)?
When would it be OK to switch Engine on (probably not) engine off?
Would it affect the controller as regards to parameters saved on it?
Thanks for any comments or ideas.
Alon
			The idea:
The problem:
Alon
