Check Engine Light!!!!!!!!!!!!!
mikedrees
the CEL light came on today:???: got codes of 132 & 551 on the scan tool, & 65 & 21 doing the ignition & odo trick. from what i can tell it says left o2 voltage high & power steering switch. for some background info: 1997 tj, 90,000miles, 2.5 & 5sp. just replaced the upstream o2 sensor about 2000 miles ago with the bosch universal type. anyone else had these probs & any easy fixes?
thanks in advance,
Mike
This may sound crazy, but disconnect your battery cables and then reconnect. It should reset the light. It worked on mine.
