Built HP30, 8.8, 36" iroks, 231 w/ SYE and more...
MoonWorks
- HP30 -
...4.88 Yukon Gears, Aussie locker, half diff guard, external axle tube seals, set up for SOA leafs. This was originally a VD axle but does have a block off plate and solid shaft in there now. Bolt in for a YJ.
- $400 by itself or $800 w/ steering listed below.
-M.O.R.E. Steering kit-
...MORE steering correction setup w/ trac bar bracket (axle side). Bracket for the passenger side knuckle has been welded in place so you'll get the knuckle as well. This was setup on a YJ.
-$500
-Ford 8.8-
...4.88 Yukon gears, LSD, disc brakes, Rockcrusher diff cover, set up for SOA leafs.
- $300
-NP231 w/ AA SYE-
...great working order, Advance Adapter SYE was installed a couple years back with zero issues.
-$350
-Tom Woods HD CV driveshaft-
...rear driveshaft that was behind the 231 listed above in a YJ.
-$125
- 4 - 36x13.5R15 Iroks -
...95% tread left, These are bias ply and were on a trail only YJ. Zero street miles and only about 8-9 trail runs on them. Great shape.
-$800 by themselves or $850 w/ rims listed below.
- 4 - 15x10 Cragar Soft 8 black steel wheels -...5 on 4.5 bolt pattern
-$100
All prices are OBO. Prices do not include shipping. All items are located in Richmond, VA so local pickup is prefered on most of these items as they are all pretty large items. PM or e-mail for more info. Thanks!
MoonWorksOffRoad@yahoo.com
