A/C Exap drain
RAVEN13xxx
Anyone know where teh A/c evaporator drain is on a ZJ?? It's leaking onto the floorboard, and I can't find the blessed thing. It looks like it's actually inside the frame!!
Hi,
I don't know exactly where it is, but have heard that it's a pain to get to. I do think it might run inside the frame.
Hmmm That didn't say much :mrgreen:
-Nick :!:
A/C Evaporator Housing - Water Leaks To The Interior
NO: 24-06-96
GROUP: Heating & A/C
DATE: June 28, 1996
SUBJECT:
A/C Evaporator Drain Blockage
MODELS:
1993 - 1996 (ZJ) Grand Cherokee/Grand Wagoneer
1993 - 1996 (ZG) Grand Cherokee (overseas markets)
SYMPTOM/CONDITION:
Debris may collect in the evaporator drain tube area causing blockage of the tube. This can lead to water leaking from the heater housing, water sloshing around in the housing and odor from decayed organic debris. This bulletin provides instructions to gain easy access to the drain tube for clearing foreign matter from the tube, without removal of the heater A/C housing.
DIAGNOSIS:
Operate the system in the A/C mode and verify that water is draining from the system. The water drains into the frame rail and exits in the center of the vehicle. If no water is draining, the system is blocked and requires cleaning.
PARTS REQUIRED:
1 5255217 Plug
REPAIR PROCEDURE:
This bulletin involves drilling a hole in the A/C evaporator housing to allow for cleaning of the drain tube.
1. Pull the carpet down in the passengers foot well and locate the evaporator drain in the housing (See Illustration).
2. Drill a 1/4 inch hole in the center of the drain tube housing as shown. Clear the drain tube with a wire or suitable tool by inserting it through the hole and into the drain tube.
3. Insert plug, P/N 5255217 into the 1/4 inch hole drilled previously.
4. Verify that the drain is clear by operating the system in the A/C mode and observing that water is draining
Look HERE for a pic showing where to drill and more information on this problem.
I've got a buddy that went through this and can get you more info if needed.
Hi,
True that there is no real Frame on Cherokees/Grand Cherokees. However they still have frame-like channels (mostly folded sheet metal) which run from front to back on either side of the vehicle to provide alot of the strength.
-Nick :!:
